查看: 362699|回复: 1321
2012年9月18日全新升级LP_wizard V10.5 ,自动生成器件封装
发表于 2010-7-31 02:05:44 | 显示全部楼层 |阅读模式
关键词: MENTOR , wizard , 破解 , 收购
截图就不更新了。10.4版本,9个附件。
System Requirements
Microsoft .NET Framework Version 3.5
LP Wizard requires Mircosoft .NET Framework Version 3.5 to function. You must install Microsoft .NET Framework 3.5 before or after installing the LP Wizard software. Later versions of Mircrosoft .NET Framework (v4.0) are not compatible.
Problems Fixed in This Release
This section describes problems fixed for the LP Wizard 10.5 release.
 DR 00875188—Via Calculator preview display is wrong, regression from 10.3.2
 DR 00887058—Incorrect pad orientation
 DR 00883089—The SOT-223 thermal pad rotation is incorrect
 DR 00882190—Excessive heel trim on pads on the long side of the thermal pad
 DR 00877681—Silkscreen is not generating properly when enabling skill scripts in
      LPW 10.4
 DR 00906115—LPW 10.4 export of BGA's to PADS 9.4 is missing alphanumeric pin
      name control for either Part or Decal
 DR 00878639—Print shows incorrect pin numbers
 DR 00898311—Mirrored or rotated print output of Shrouded right angle header land
      pattern
不知道LP Wizard是啥的,看下边两个帖子
http://www.eechina.com/thread-5719-1-1.html
http://www.eechina.com/thread-979-1-1.html
下载:
LPWizard_10.5_ESDM.ix2k.part01.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part02.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part03.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part04.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part05.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part06.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part07.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part08.rar (9.75 MB)
LPWizard_10.5_ESDM.ix2k.part09.rar (8.34 MB)
破解下载地址:http://www.eechina.com/thread-111500-1-1.html
CAD outputs changed in LP Wizard 10.3.2
A number of LP Wizard tool outputs were changed beginning with the LP Wizard 10.3.2 release.
Users of all the EDA tools listed as having their 'direct' -that is, "named" - CAD Output support removed should determine if the Universal Cad Output, PADS ASCII (PADS or *.d, *.p), can be utilized for their EDA tool going forward.
Below is a breakdown of what is now supported in LPW.
Directly - Tool specific CAD Outputs LPW
*    Allegro
*    OrCAD PCB Editor
*    Board Station
*    Expedition
*    PADS Layout
*    PADS Layout ASCII
Indirectly -These CAD tools use the above PADS Layout and/or PADS Layout ASCII CAD Output in LPW and can import PADS Layout ASCII.
*    Altium (PADS ASCII and V5.0  PADS .p & .d files)
*    Pulsonix (PADS V5.0 and V2007)
*    CADSTAR
*    Pantheon
*    CR-5000
These LPW CAD Outputs were removed:
*    McCAD
*    Ultiboard
*    OrCAD Layout
*    P-CAD
*    Eagle
LPW previously had the ability to create CADSTAR .cpa  library files, this is no longer available with 10.3.2 and newer. LPW 10.3.1 last had this ability.
发表于 2010-7-31 09:52:28 | 显示全部楼层
好,支持
发表于 2010-7-31 09:53:18 | 显示全部楼层
好,
发表于 2010-7-31 11:18:17 | 显示全部楼层
谢谢!
发表于 2010-7-31 16:34:21 | 显示全部楼层
顶,狂顶!
发表于 2010-7-31 16:44:45 | 显示全部楼层
学习学习
发表于 2010-7-31 22:57:24 | 显示全部楼层
非常的需需要,谢谢
发表于 2010-7-31 23:16:21 | 显示全部楼层
好东西要顶
发表于 2010-8-1 16:23:29 | 显示全部楼层
回复1楼fenghaili 谢谢楼主
发表于 2010-8-1 18:52:27 | 显示全部楼层
好,支持
发表于 2010-8-1 19:16:09 | 显示全部楼层
好东东,谢谢楼主
发表于 2010-8-1 22:10:30 | 显示全部楼层
thank
发表于 2010-8-1 22:26:27 | 显示全部楼层
Hey !! Thanks
发表于 2010-8-1 22:34:55 | 显示全部楼层
自动生成器件封装
发表于 2010-8-1 23:49:42 | 显示全部楼层
Good job. 回复1楼fenghaili
发表于 2010-8-2 09:17:43 | 显示全部楼层
这个软件生成pcb封装后导入pads 怎么看不到丝印,只有焊盘?
 楼主| 发表于 2010-8-2 10:37:29 | 显示全部楼层
gsywm 发表于 2010-8-2 09:17
看不到丝印,是因为你设置了丝印的颜色与背景色颜色一样,都是黑色,所以你看不到丝印。
发表于 2010-8-2 10:54:37 | 显示全部楼层
好 支持!
发表于 2010-8-2 12:26:04 | 显示全部楼层
THANKS
发表于 2010-8-2 12:40:39 | 显示全部楼层
哇,这个是最新版的吧,楼主真强
